G
Guest
Guest
I have the following configuration:
Epox K7A+ Motherboard
Athlon 1.33GHz
Eagle3D nVidia MX400 32MB
Sony 52 CD-ROM
Iomega CD-RW 16x10x40x
Whenever I try to drag and drop files onto a blank CD using DirectCD the system hangs. There is no problem when I copy files using Easy CD creator 4 though.
Also, there are a few occasions when I get this message on the Easy CD Creator 4 when I select CD Information : Bad Medium....
I have to reinstall the whole Easy CD Creator 4 to be able to record CDs again! Help!!!
The end is the beginning :frown: is the end is the beginning is the...
Athlon 1.33GHz
Sony 52 CD-ROM
