Serious problem with game fps.
Okay so I recently built my new computer everything working great until I try and play Deus ex: Human Revolution. Just in the menu's I've been getting 5-10 fps which is horrible all the settings are as low as they can go and still the same problem. My specs should easily handle this. I can get 60 fps in Arma 2 and Batman Arkham asylum this has really confused me.
Here are my specs for a reference.
6 answers Last reply
More about serious problem game
  1. What percentage are the CPU and GPU at when you run the game?
  2. are you using the latest driver?
    How do I find out?
  4. since its menu and theres no reason for much usage i assume the graphic cards downcloaks itself and therefore it shows just few fps :)
    my 5750 has 700mhz but when using desktop i get shown just 400mhz gpu frequency
    best
    revro
    best
    revro
    In game it's just as bad..
  6. Use a program like HWMonitor to check if the GPU's temperature increases while you're running the game. That way you could tell if it's even using the GPU. Or if it's loud enough, you could just try to hear the fans speed up :D
Nvidia Games Computer FPS Graphics
