Sign-in / Sign-up
APU A10 5800k temp. issue,. Help!
  • CPUs
  • Cooling
Last response: in CPUs
February 26, 2013 2:22:35 PM
hello guys i have a problem with this CPU i dont know if is normal to hit 65-70°C on games
My cpu go from 40°C iddle to 65°+ in ten minutes full load. CPU cooler is the original and the cabinet has a rear cooler draws air and i check the thermal paste and it's fine.
It is more effective to put more coolers in cabinet or improve cpu cooler to lower the temperature?
(sry my english) :bounce:
More about : apu a10 5800k temp issue
a b à CPUs
February 26, 2013 2:51:12 PM
Max sure the the CPU heatsink is installed correct and what software you using to check your temps? Whats your Mobo??
m
l
February 26, 2013 2:58:27 PM
i checked the heatsink 2 times and is installed correctly. im using an ASUS F2A85-M LE . and a mobo software to monitoring the temperature (AI Suite II) .
m
l
a b à CPUs
February 26, 2013 3:07:00 PM
have you tried any other software? is the temps in bios and Ai the same? i have the same A10 5800k (not in a pc build) my temps never go above 60C and idles about 30C
m
l
March 4, 2013 11:17:32 PM
I have one as well, I play Aion on full settings using a discreet Radeon Hd 6860. About ten minutes into my game, My Ai suite sensor warning pops on letting me know that my temps are at or above 60 Celsius. I have an Asus F2a85-V-pro mobo. I was wondering what the mximum temp is for the cpu before I really need to worry.
m
l
a b à CPUs
March 5, 2013 1:12:52 AM
Its 74C according to this
http://www.cpu-world.com/CPUs/Bulldozer/AMD-A10-Series%...
m
l
May 17, 2013 6:46:08 PM
My Also have a F2A85-V PRO mainboard with a A10 5800K.
At the moment I'm re-codeing a BDRip with Handbrake and this is what it shows using CPUID Hardware Monitor.
http://t.co/3Bg0mYTUv9
m
l
a c 591 à CPUs
May 18, 2013 4:45:43 AM
What's your room temperature?
m
l
July 11, 2013 10:25:08 PM
Have u enable turbo funtcion of cpu fan?
m
l
