24-pin power cable won't go all the way into motherboard
Last response: in Components
- SolvedCan't Push Motherboard 24-pin Power Cable In All the Way Forum
- Solved24 Pin Psu motherboard cable won't go into the plug all the way. Forum
- 24-pin ATX Power Cable will not clip on to motherboard but still provides power... Is this a problem? Forum
- 24Pin Power Supply won't latch to motherboard Forum
- SolvedPSU Main 24-pin Power Cable Doesn't fit Forum
- SolvedPSU Cable to power the motherboard allegedly "Won't Fit" in the slot. Forum
- SolvedPsu power cable won't stay in motherboard Forum
- Motherboard shows power up only when power cable half way in Forum
- 24-pin power connector does not fit in motherboard socket correctly - Bent pins? Forum
- SolvedPcie cable won't connect all the way into Gpu Forum
- Where does the power switch jump cable go in my motherboard? Forum
- How do I rig power supply to handle both 24-pin and 20 pin motherboard Forum
- motherboard power cable won't click in Forum
- SolvedMy Sata cable won't go in the SATA port Forum
- Solved6+2 pin pci-e connector won't go all the way in 6 pin pci-e slot Forum
- 24pin power supply into 20pin motherboard Forum
- I'm using asrock motherboard G14M VS2 I don't knw where the power sw , power led , hdd led, reset cables go the power on ma pc Forum
- Power/led case cable won't fit motherboard pins? Forum
- SolvedUnplugged power cable to PSU and moved pc, now it won't start Forum
- 24-pin Power Supplies: What's going on? Forum
- More resources
Read discussions in other Components categories
