Closed
Do I need these parts for a gaming computer?
Last response: in Components
February 26, 2013 11:01:28 PM
Hello, do I need these parts for a gaming pc?
-Surge Protector
-Network Interface Card
-USB2 card
-optical drive
If I do, can you please list what is required? Thanks!!!
BTW can you recommend a SATA Drive?
Thanks Again!!!
More about : parts gaming computer
a b 4 Gaming
February 26, 2013 11:20:55 PM
You might need an optical drive to install windows.
Network card is integrated into motherboard nowadays. So is the USB.
You must have been out of the loop quite a while.
And what do you mean by sata drive? A hard drive, SSD, or an optical drive? They all use sata.
If you meed more info, read up
http://www.build-gaming-computers.com/
Score
February 26, 2013 11:22:32 PM
a surge protector should be used, no matter what kind of pc you have.
a NIC would come built in on any modern day motherboard, so you really wouldn't need a separate card.
USB2 also comes standard on new motherboards (USB3 as well)
optical drive, yes that would be needed, depending if its Sata or IDE thou, as most new motherboards do not support IDE devices anymore.
and you asked a recommendation on a SATA drive? are you asking about a hard drive?
Score
February 26, 2013 11:27:17 PM
I read these requirements out of a website, but thanks anyways. Isn't the HDD pretty much the hard drive?
Score
Best solution
February 26, 2013 11:30:28 PM
I always use a surge protector just in case...
You should not really nead the interface card unless your mobo has really slow or inconsistant internet.
should not need usb card unless you use more usb devices than you have plugs on your mobo...
Always need an optical drive, if for nothing else than to load windows, and make repair disc.
Recommended sata drive (s)...
System drive http://www.microcenter.com/single_product_results.aspx?...
Storage drive http://www.microcenter.com/single_product_results.aspx?...
second choice http://www.microcenter.com/product/334293/Barracuda_1TB...
February 26, 2013 11:35:14 PM
thanks for your help and suggestions!!! :)
Score
February 26, 2013 11:42:01 PM
Please pick a best answer when you feel your questions have been adequately answered... if you have any more questions come back!!
Score
February 26, 2013 11:48:16 PM
Best answer selected by Tommy6545.
Score
February 27, 2013 12:42:57 AM
Hi :)
NO
YES
NO
YES
All the best Brett :)
Score
a b 4 Gaming
February 27, 2013 8:53:18 AM
This topic has been closed by Maziar
Score
