Please provide feedback/advice on my i7 system build....
Time to build a new WorkStation. My primary uses will include photo editing with Lightroom and Photoshop, three D graphics using Three D studio Max, Maya and Mud Box, HD video editing using Premier and After Affects and some Web Design. I seldom run games. I'm running two Dell U2410's.
I have picked the MSI motherboard due to its support for 128gb ram, superior auido and other high end features. The second for its rep for solid value/performance. Opinions.
I am uncertain about ssd Raid0, some say it really helps performance, others say it makes for good benchmarks without real world improvement.
Finally, I would like some advice on video cards. I prefer nVidia to ATI, but I'm not sure which chip to go for. The six fifties are cheaper, but the 660 provides more CUDA cores. I'm not sure about the difference between TI versions and non TI versions.
Any advice is appreciated. Thank you for your expertise.
Processor
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
$329 w/ship
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Mobo
MSI X79A-GD45 (8D) LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
$219 w/ship
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130635
or
ASRock X79 Extreme6 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$240 w/ship
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157289
Memory
G.SKILL Ripjaws X Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL10Q-32GBXL
$130
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231490
Hard Drive
2 ea. ADATA S510 Series AS510S3-120GM-O 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) - OEM
$180
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211588
Video
EVGA 01G-P4-2650-KR GeForce GTX 650 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
$120
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600030348%20600315498&IsNodeId=1&ShowDeactivatedMark=False
or
EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
$230
Optical Drive
LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-Ray Burner with SW, 3D Play Back - BH14NS40
$60
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136249
Case
ZALMAN Z11 Black Steel / Plastic ATX Mid Tower Computer Case
$50
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119106
Power Supply
Rosewill Green Series RG630-S12 630W Continuous @40°C,80 PLUS Certified, Single 12V Rail, Active PFC "Compatible with Core i7,i5" Power Supply
$60
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235033
Total $1280
or 1150
3 answers Last reply
More about please provide feedback advice system build
  1. The motherboards and processor are incompatible. Those are LGA2011 boards and a LGA1155 chip. Both need to be the same.
    SSD's are not that great. Go for a Samsung 830 or OCZ Vertex4. I dont think you will find any real benefit of RAID0'ing two SSD's. The money could be better spent getting a HDD/s for mass storage, which your workstation rig is currently lacking quite badly.
    GPU can be entirely skipped if its just a workstation rig. Both are not very powerful gaming wise, not sure about their CUDA performance. An AMD card may be a better option due to superior OpenCL and GPGPU performance, if your application can use it.
    The Ti on the end of some cards basically means its just a new card, not a modification to the non-Ti model. Suspect they did it for naming reasons, otherwise they would have too many numbers to fit the current scheme, so they added letters instead.
    That PSU is a no. The Power Supply is the last place to skimp in a build.
    You want a proper unit like this XFX 650W. $100 ($10 rebate)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
    What is your overall budget? If you fill out this form we may be able to help you build a rig, as so far it wont work and some components (SSD's, case and PSU) are not ideal.
    http://www.tomshardware.com/forum/353572-31-build-upgrade-advice
  2. Rosewill hive and capstone are better psu's.
    Go with the 660. Better card.
    You can get the non K 3770 if you're not overclocking,and a z77 board. Otherwise you want low profile ram like gskill Ares,Sniper.
    Raiding SSD's adds nothing, get one larger capacity one. I'd also switch the brand to Samsung, Crucial,Corsair, or Mushkin.
  3. Thx for all the advice. I have adjusted my build as per advice and made a new post in new builds following the t's HW build post guidelines. There is no reason to continue this post because the system is unworkable.
    please post any new comments here:
    http://www.tomshardware.com/forum/366901-31-adjusted-build-feedback-sought
Homebuilt Systems Product
