Closed Solved
PSU question help!?
Hi, I'm a low level-mid range gamer (I don't do anything extreme) and I am looking to upgrade my PC however in order to continue upgrading, im going to need a better PSU, and I need to know if this will fit in my Thermaltake V4 black edition case
http://www.stardot.com.au/thermaltake-600w-tr2-bronze-psu.html
(****DO NOT RECOMEND A DIFFRENT PSU :non: , IM SIMPLY ASKING IF THIS ONE WILL FIT****)
My specs
Intel i5 3470 @ 3.2Ghz
Kingston Hyper X RAM 8GB @ 1600 Mhz
GA-B75M-D3H Gigabyte motherboard
Nvidia GT 640
1TB Seagate
Thermaltake V4 black case
Also please don't say that I need a better graphics card (I already know)
Thanks
6 answers Last reply Best Answer
More about question help
  1. Best answer
    PSU's are a standard size unless you get up to about 1000w+. So yes, it will fit.
    ok cool thanks :sol:
  3. Best answer selected by Quadacon.
  4. It will fit....but make sure it has enough Amps(this is where your extra power comes from). You can have 1000watts and but won't have enough Amps.....your PC will shut down momentarily.
  5. It will fit....but make sure it has enough Amps(this is where your extra power comes from). You can have 1000watts and but won't have enough Amps.....your PC will shut down momentarily.
  6. This topic has been closed by Maziar
Power Supplies Thermaltake Components
