Approximate Purchase Date: within the next few weeks
Budget Range: Final cost ~£800-900
System Usage from Most to Least Important: gaming (eg. Dota2, SC2, Diablo 3), internet, movies, video editing (not a huge amount)
Are you buying a monitor: Yes but not included in cost. Current screen 22", new will be 23/24"
Parts to Upgrade: New Build, so all
Do you need to buy OS: No - Win7
Preferred Website(s) for Parts: www.overclockers.co.uk, www.scan.co.uk, www.ebuyer.com, www.amazon.co.uk
Parts Preferences: Intel CPU
Overclocking: Yes but not straight away
SLI or Crossfire: Yes later x2
Your Monitor Resolution: 1680x1050 (current and minimum), 1920x1080, 1920x1200
Additional Comments: Dota2, SC2, Diablo 3. Preferably not too loud
And Most Importantly, Why Are You Upgrading: Replacing family pc with my current one (just over 2yrs old)
Currently looking at:
Processor: Intel i5 3750k £168 from Scan/overclockers
GPU: MSI HD 7870 twin frozr £184
Thanks for any help you guys can give.
