Need Mid-Level graphics Card for 3D design
So I have a fairly low end custom built PC and I want to run Autodesk programs on it. Specifically 3ds MAX and Maya. I'm currently using the onboard graphics from my motherboard which has a fairly high quality display but cant handle the grunt work from these programs. I'm hoping to stay under $100 if possible but I'm also not creating huge scenes for the most part so I dont need anything really high end. I know very little about graphics cards so I cant figure out which features I should be focusing on since my goal isn't gaming.
I have a DG43NB motherboard and an Intel Core 2 Duo processor. I know I have enough Power to use the cards in this range and my RAM is the same as the programs recommend.
512 Mb is the minimum requirement for the program
1 GB is recommended
If anyone has a specific card to recommend that would be helpful but I'm very interested in what specific specs and features I should focus on while looking to buy.
Thanks very much for any help anyone can provide.
1 answer Last reply
More about need level graphics card design
  1. I think this one should work pretty well.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161403
    It is only 5 over budget.
Graphics Cards Graphics Product
