Case
Last response: in Components
Good Evening,
My case is an IN-WIN Griffin. It already has stand offs integrated with it (my first build) so do I just use the screws and screw it where the holes match up with the mobo?
More about : case
I'm a little confused by what you mean.
Yes, the standoffs receive screws after you place the motherboard over it.
Most cases now come with two standoffs already installed. You install the additional standoffs per your motherboard size. The manual should list out which holes to add them to.
Does that answer it? Or did you mean something else?
Related ressources
- Is it possible to build using dell or emachines case ? - Forum
- Needing to get a new cpu fan/ case fan - Forum
- Intel Pentium E2180 help - Forum
- Electric current trogh my pc case - Forum
- I/O Shield does not fit in Case - Forum
They go in the middle somewhere, just take your board and hold it in the case so the rear ports are in the correct position in the case, you can see where those two are supposed to go.
Alternatively, just put the rest of the stand offs in your case as per the instructions for your type of motherboard, and then put the motherboard in the case so the rear ports are in the right place and you will see where it all goes.
USmc2010 said:
OK. I see two holes that are right behind the mobo. My only quest following that is, since the mobo would be covering the two standoffs ( and no possible ways to screw a screw in) do I just put the stand offs in and lay the mobo on top?Absolutely not. You run the risk of shorting components if you do that.
Make sure you're positioning the board correctly.
I searched up your case (http://www.hardwaresecrets.com/fullimage.php?image=2381...) and it looks like the standoffs are already integrated. Can you take some pictures of what you mean by there's no way to put screws in?
Edit - see my next post
Best solution
Related ressources:
- ForumMicro atx desktop case that will fit a NH-D14
- ForumCan someone help get a CPU cooler and another case. ty
- ForumNeed PC case to fit a Gigabyte GeForce GTX 670
- Forum[Solved] Fitting a noctua nh d14 in micro atx desktop case (horizontal)will it
- ForumNew Graphics Card, Case Fan and Case?
- ForumCase Fans
- ForumMost durable steel case out there?
- More resources
Read discussions in other Components categories
