Monitor onl has VGA, Grpahics card has DVI, HDMI and display port
  • Graphics Cards
  • Monitors
  • VGA
  • Graphics
August 22, 2012 11:09:07 PM
I recently received a new graphics card from a friend, here is a link to it http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The problem that I have come across is that my monitor only has a VGA/D-Sub port on it and the new graphics card has HDMI, DVI(24+1 pin) and a display port. I have been looking around for some sort of adapter and have come up empty so far and asking here looks like my last resort. Is it possible to use my VGA monitor with this graphics card?
Apologies if this is in the wrong section. Thanks for your time.
More about : monitor onl vga grpahics card dvi hdmi display port
August 22, 2012 11:20:29 PM
I think that is a 24+5 dvi adapter. I have a 24+1 on my graphics card.
m
l
August 23, 2012 5:13:24 AM
I don't know, I heard going from vga(analog) to dvi-d dual link is impossible.
m
l
a c 104 U Graphics card
a b C Monitor
August 23, 2012 10:11:40 AM
You heard wrong then.
Maybe they meant the other way round. A gpu with a analog output to a monitor with dvi input or something.
My son uses an adapter like that and it's working fine. gpu 6870 dvi out ->adapter-> vga input monitor.
What monitor do you have btw ? Lcd i assume ? Not a prehistoric one with the glass screen ?
m
l
a c 291 U Graphics card
a b C Monitor
August 23, 2012 10:44:13 AM
No he did not hear wrong. It is impossible going from DVI-D to VGA through a simple adapter. Your son must have DVI-I slot on his graphics card, not DVI-D.
As for the OP: if you don't want to change the monitor, you'll need an active adapter. Those are costly, and depending on the monitor you have, they might not be worth it (when you can get a new monitor for $150)...
m
l
a b C Monitor
August 23, 2012 10:47:44 AM
Ok then, second time you prove me wrong :??:  Meh ! :(
Why do those adapters exist then ?
I specifically looked for the DVI-D dual link to vga.
m
l
a b C Monitor
August 23, 2012 10:56:03 AM
I don't really know, but if you read the review on any of those sites about the adapter, you'll see that people who bought it couldn't make it work. The reason for this is that DVI-D slot doesn't transmit analog signal, which is needed for VGA output. You need a converter which converts the digital signal to analog one.
m
l
a b C Monitor
August 23, 2012 11:07:49 AM
Ok, thanks for that info. Every day you learn more . . .
I figured that if such an adapter exists that it would be possible, why make such a thing in the first place then anyway ? Probably stupid to have so much faith in our loved manufacturers.
Think i shut up for now and gonna sit in a corner and sulk for a while, hate giving wrong info. :(  ( specially two days in a row )
m
l
a b C Monitor
August 23, 2012 11:49:48 AM
Don't feel bad, we all make mistakes ;) .
m
l
