Wireless connection
slick18
Hello,
my laptop has lost wireless connection completely even wen l try to connect its not even detecting any of the wireles connection around like it normally does so wot do?
Hello and welcome to Tom's Hardware Forums.
Simple suggestion first - is it switched on? Some laptops have a tiny switch on the front or side - others use one of the Function keys in conjunction with the Fn key to the left of your spacebar. The Function key might have a wireless icon similar to ((0)).
