Need help to make sure parts will work together
hi i am building a Gaming PC and i want to make sure the parts will work together
CPU - Intel Core i5 3570K
GPU - Gigabyte Radeon 787O 1Ghz edition
Motherboard - Gigabyte GA-Z77-D3H
PSU - Corsair CX-430 (430W) (UPDATED)
HDD - WD Caviar Black 1Tb
RAM - 2x4Gb Corsair Vengeance Performance (CMZ8GX3M2A1600C9B) (UPDATED)
9 answers Last reply
More about need make parts work together
  1. Good build.
    remember that you wouldn't be able to do cfx the best. I would cut out the 16gb ram and get this instead
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233335&name=Desktop-Memory
  2. umm link is not working
  3. Also, if you are planning to overclock, you are going to need a better cooler for your CPU. A CoolerMaster Hyper 212 EVO should do the trick.
    If you don't really feel like overclocking, then a cheaper board and processor would be a better idea and would save you money.
  4. ok i have updated the parts list
    replaced PSU to 430watt and changed the ram to 8Gb
  5. You might want a beefier power supply for that computer, like a CX500.
  6. You could probably make due with a 430watt but it won't be able to due much overclocking. I would get a 500w or 530w instead
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182199&name=Power-Supplies
  7. I wouldn't go with a 430w.
    It will probably work but it's gonna push the PSU to its limits.
    Hell, even AMD doesn't suggest it.
    http://www.amd.com/us/products/desktop/graphics/7000/7870/Pages/radeon-7870.aspx#2
  8. I would go 500
New Build Systems Product
