GTX 560 is running @ 107C. Tested with Hwmonitor pro and GPU Z. Its making it difficult to do any work. Is there any fix or do I have to find a replacement?
you will definately need to remove the heatsink, reapply thermal paste, and attach the heatsink correctly back. the paste probably died out if you are reaching that temperature(or you have some weird overclock)
Is the temp constant? 107 degrees could indicate a faulty sensor to, so try not to panic. check your cooler, remount it with new termal paste etc and veryfy the screws.
