Gigabyte Geforce GTX 670 Windforce Problem? PLEASE HELP!
Hi, i received my 670 yesterday and although the card is amazing, I'm having a small noise issue. Basically, if you've seen the card it has 3 fans. And although these fans are pretty much silent, 1 is giving me problems. It is as if the middle of the fan circle is rubbing/brushing against something and making a small noise. Now, although the noise is pretty unaudible unless my ear is next to the PC, it still bugs me. Do you guys no if this is normal? Is there an easy fix? Or is it worth replacing?
Thanks in advance!
1 answer Last reply
More about gigabyte geforce windforce problem help
  1. If one fan is louder than the other, or it sounds like it's rubbing something, then it's not normal.
Nvidia Gtx Gigabyte Geforce Graphics
