So its time I built a new gaming computer and I could use your guy's help. My budget it 1000 and I am currently at 1070. Id like to shave off a little more money if I can. Here is the build.
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
Hard Drive- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
PSU- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
MOBO- http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
So I was thinking what to do and i noticed the mobo came with some free RAM, if you think the ram is good enough then I can get rid of the G-skill and shave 40 bucks off which would be good enough. Here is the ram the MOBO comes with http://www.newegg.com/Product/Product.aspx?Item=N82E16820220558
Also I just wanted to know if everything is compatible. And which GPU do you think I should go with I was stuck between these two
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130810
The MSI has better stats but I feel like evga is more reliable. Thanks in advance for the help.
