Monitor no signal via DVI-VGA Adapter
Specs
http://www.newegg.com/Product/Prod [...] 6883227339
Phenom II X4 955(3.2GHz)
4GB DDR3 1TB HDD Capacity
NVIDIA GeForce GT 520 (1 GB)(Replaced)
Windows 7 Home Premium 64-bit
PSU : SeaSonic S12 Energy Plus SS-650HT 650W ATX12V V2.3 / EPS1
New GFX : EVGA GeForce GTX 560 1024 MB GDDR5 PCI Express 2.0 2DVI/Mini-HDMI SLI Ready Graphics Card, 01G-P3-1460-KR
Adapter:
Amazon.com: StarTech DVI to VGA Cable Adapter, M/F (DVIVGAMF): Electronics
(StarTech DVI to VGA Cable Adapter, M/F (DVIVGAMF)
Current Monitor is like : http://www.saintclassified.pk/uploads/dell-17-inch-fresh-5e2ed.jpg
I bought a new PSU and New GFX card and an adapter because the GTX 560 has 2 DVI connectors. So I seated the GFX, Put in the pins, try both slots with the adapter and the monitor(VGA), but NOTHING APPEARS.
I tested with old GFX(520) and monitor is fine. I tried reseating GFX card, different 6 pins from the PSU, different VGA monitor and adapter, replugging in the cords for PSU and Monitor, onboard VGA slot but none of these worked.
I can't see or do anything with the VGA Monitor unless it's with the old GFX card. Please help!
2 answers Last reply
More about monitor signal adapter
  1. how do you connect the GFX 520 to the monitor? Same cable, same adapter, same port on back of monitor?
    Mac
  2. Your links are broken, so I can't tell which EVGA card you have. But to use VGA from a DVI connector on the card, the connector has to have the 4 pin holes surrounding the flat blade. Those are the VGA signal. Likewise, the adapter has to have the 4 pins surrounding the flat blade. Does your setup have that?
Prebuilt DVI Monitors VGA Systems Product
