Hello
I am going to build a computer and I need fast wireless adapter for gaming since the router is not near this computer.
Right now I am considering 450Mbps Wireless N Gaming Adapter TEW-687GA(http://www.trendnet.com/products/proddetail.asp?prod=225_TEW-687GA&cat=42) and 450Mbps Dual Band Wireless N USB Adapter TEW-684UB(http://www.trendnet.com/products/proddetail.asp?prod=195_TEW-647GA&cat=42), which one be faster between the two?
I am also considering D-Link DWA-556 Xtreme N PCI Express Desktop Adapter(http://www.amazon.com/D-Link-DWA-556-Express-Desktop-Adapter/dp/B000N4WRFY/ref=sr_1_1?ie=UTF8&qid=1318209908&sr=8-1) will the pci be faster and more stable than the two above or will it be slower?
I also found AV Ethernet adapter
http://www.amazon.com/TRENDnet-Powerline-Ethernet-Adapter-TPL-401E2K/dp/B004D9V8C8/ref=sr_1_3?ie=UTF8&qid=1318209118&sr=8-3
http://www.amazon.com/NETGEAR-XAVB5001-Powerline-500-Adapter/dp/B004DVEW8I/ref=sr_1_1?ie=UTF8&qid=1318209118&sr=8-1
Will the AV Ethernet adapter be faster than wireless above?
I don't really worry about the cost, I need the fastest internet speed possible.
Any other recommendations are welcomed.
thx
thx
