Need Help!! No hard drives detected after new video card
Last response: in Systems
Homebuilt system Authority
Graphics card Master
If you feel them (of course after discharging yourself of static electricity) they should feel like they are vibrating.
Which 850W are you using?
Related ressources
Could be a couple of reasons. First though make sure that the hard drivers are starting up. It is most likely that they are not at fault and this is to just make sure they are getting power.
Thermaltake Black Widow 850W I am guessing. Not the best there is but should be able to pull a 560Ti and a couple of hard drives.
Well, if it doesnt pick up the drives with your new power supply and it does with your old one, then there might be an issue here.
i ran my win7 cd and if i go through install i am able to see the drive, but if i try to repair from that drive it doesnt recognize a partition. I am just going to try to reinstall, I was due for it anyway
Ill let you know how it does. Still not understanding why such trouble to swap a vid card, never had issues before.
In the process of trying to figure out what my pcs issue was i noticed that my sata speed was set to auto seeing as i had a 320gb and 2 1TB WD Black editions. it was only running at 3.0gb/s wow what a difference after I switched it to 6GB/s . windows installed in no time flat!. I have since removed the 320 drive as I wasnt using it anyway! Thank you for all your time and patience.
Ask the community
