Completed Builds - Questions - Custom Water Cooling Advice - Advice
  • New Build
  • Water Cooling
  • Systems
  • Product
Last response: in Systems
October 18, 2012 8:14:49 PM
Looking for some input:
Here is my build:
CPU: Intel Core i5-3570K
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Price: 229.99
GPU: HIS - AMD Radeon 7850 2GB - 256-bit
Price: 194.99
NOTE: I do not care about all the eye candy in games. Xbox 360 graphics are perfect for me. I ust want medium settings at a solid 30FPS and I would be happy here.
Mobo: Asrock Z77 Extreme 3 - LGA 1155
Price: 119.99
Memory: G.Skill Ares Series 8GB (2x4GB) (Quantity: 2)
Price: 38.99
Storage: Seagate Barracude 1TB 7200RPM
Price: 89.99
Cooler: Cooler Master Hyper 212 Plus
Price: 29.99
Case: Cooler Master HAF 922
Price: 99.99
PSU: RoseWill 750W PSU - Gold Rated
Price: 109.99
Keyboard: Microsoft Sidewinder X4
Price: 49.99
NOTE: I probably will hold off on buying this as well.
Miscellaneous:
1: VGA too RCA Adapter
My Budget: (As of right this second) = $1000
I wanna future proof my system as much as possible. Without going overboard and all.
I do NOT need: OS, Keyboard/Mouse, Optical Drives, Monitors.
WATER COOLING:
NOTE: I have chosen the Hyper 212 Plus cooler for now.
I plan to get a custom water cooling kit in the future. I plan to spend maybe $200 or so on a custom water cooling kit. What I'm wondering is, is it going to be worth it? I've always wanted a water cooling kit. I've really been considering a closed loop solution as well just because I really want water cooling.
I've been considering the Corsair H60/H80. From what I get these are not worth it however. Can someone give me some more input on this?
Also, can someone recommend me a good custom (hopefully like a prebuilt water cooling kit) for around 100-150 Dollars (maybe even 200 if thats not possible). Please help me out on this aspect. I will be ordering a custom kit in the future if the H80 really is a horrible idea and I'd be much better off without it.
How hard is it co put one of these together? I've never built a computer before.
I've been considering this: http://www.swiftech.com/apogeedrive2.aspx - Is it worth it? Does it have everything I need? Is it decent? How hard is it to assemble?
Overclocking:
I plan to slighly overclock for the time being, but I will probably attempt to do more than just a tiny bit once I have a better water cooling kit.
My plan right now is to OC too about 4.2ghz roughly...
Also looking for input on overclocking suggestions, advice ect.
Power Supply:
What i'm also wondering is, is a Gold rated good quality PSU really gonna save me money in the long run. I'll probably have my computer on about 24/7 (is this bad for a computer?), It obviously wont be at max load 24/7 but I would guess for about 8-10 hours a day will be about 60+%.
So Should I save some money and get a Bronze rated PSU? I don't want a huge power bill. Should I stay at 750W or would 550W be just fine? I'm leaning towards 650W personally. Advice would be appreciated.
I might CFX my GPU in the future as well. I'll be doing some OC'ing and major OC'ing in the future when I have custom water cooling.
More about : completed builds questions custom water cooling advice advice
October 18, 2012 8:31:02 PM
**** You don't care about eye candy and you think an xbox is just fine?
What the heck are you thinking about custom watercooling for then.
m
l
October 18, 2012 8:33:35 PM
Ok, well getting off topic at this point. And its already stated in my original post. And I don't see a point in this reply. Simply because I want too.
m
l
October 18, 2012 8:36:12 PM
Thoughts: I currently have a smaller closed loop cooler and have been thinking about upgrading to a "real" custom water cooling solution. Mostly because the graphics need to be cooled just as much as the processor does, particularly if I move to crossfire.
IMO - I'm not sure boxed closed loop water cooling systems are worth it. Yes, they are incrementally better than air coolers, but its not a huge difference and sometimes there is gurgling noise (and they are much more expensive).
With regard to the PSU - It would take a while to get a full financial return on a gold PSU because the difference is really between like 85 and 95 percent efficiency. Where this WILL make a big difference is heat. I noticed a large difference in heat output/fan noise when switching from an 80+ PSU to a Gold-rated PSU with variable speed fan.
You would be good with 550w now. Could pull off 500w with current specs and overclock, but 600-650 is a nice healthy margin. When it comes to 2 card crossfire and overclock then I would call 650w your floor.
Edit: From Techbargains: Newegg has the Corsair Professional Series HX650 650W ATX (80PLUS GOLD) Power Supply for a low $82.99 Free Shipping after rebate and Coupon Code: "CorsairOct16" (Exp 10/22).
m
l
October 18, 2012 8:44:30 PM
Custom water is worth it if you want it. Closed loop never worth it IMO.
m
l
October 18, 2012 8:48:07 PM
Any suggestions on a good water cooling kit? Is the one I posted above decent quality?
m
l
