Hi,
I'm in the middle of gathering all the parts I need for my first ever build but I'll need your help with the last few.
What I've so far...
CPU: I5 3570K
MOBO: P8Z77-V
RAM: Corsair vengence blue LP* 8gb
SSD: Samsung 830 256gb
GPU: GTX 670 ~ haven't decided which make yet.
PSU: ???
OS: ???
Case: ???
A few Q's
1). Should I get the OEM or retail version of windows 7? I've heard that after the OEM version is installed you cannot change or replace any parts, correct? Would it be better to invest in the retail?
2). Do I need a cooler? I'lll overclock whenever my PC can't run games at stock speeds but hopefully that won't be for a couple years. Should I get a fan now or wait? Which CPU fan would you recommend? Watercooling maybe?
3). I think a 650w PSU will be enough for overclocking, right? How's this? ~ http://www.amazon.co.uk/gp/product/B004O0P9TO/ref=ox_sc_act_title_1?ie=UTF8&smid=A3P5ROKL5A1OLE ~ It seems like a quality PSU but some have complained about the noise... Maybe a modular Seasonic would be a better choice?
4). Fractal design define R4. I really like its look but I'm a bit hesitant because it's a slience oriented case and I'm not sure if it can fit a decent CPU fan or water cooling setup. Does anyone know if this is possible?
Thanks in advance guys
What I've so far...
CPU: I5 3570K
MOBO: P8Z77-V
PSU: ???
OS: ???
Case: ???
A few Q's
