First of all, i apologize for double posting in two days apart, but i had to change my plans and probably going to buy the new computer tomorrow. So i thought i should ask for your help one last time.
Approximate Purchase Date: Probably tomorrow, at worst next thursday.
Budget Range: around 1000 - 1500$
System Usage from Most to Least Important: Gaming, Engineering programming ( catia, ansys, matlab vs), surfing, watching videos
Are you buying a monitor: No
Parts to Upgrade: everything since i'm building from scratch
Do you need to buy OS: No
Preferred Website(s) for Parts:http://www.novabilgisayar.com/pc.asp, http://www.vatanbilgisayar.com/
i know these are in turkish so sorry about the incovenience.
Parts Preferences: I'm an intel user, but i'm willing to change it
Overclocking: Maybe - i haven't done any overclocking so far, but if the gains are too many, i might learn.
SLI or Crossfire: Maybe same with overclocking.
Your Monitor Resolution: 1680x1050 right now, but i want to upgrade to a monitor with 1920x1080, 120 hz refresh rate,
And Most Importantly, Why Are You Upgrading: My 5 year old system starts to have some troubles mostly in everything. So i've decided to build a new one and format and give my old one to my brother or mother. And i want this new system to last at least 4 or 5 years minimum.
so Here it goes:
Cpu:
INTEL i5 3550 3.30 GHz Quad Core Socket 1155 6MB, 22nm, 77W
http://www.novabilgisayar.com/bilgi.asp?ID=8316
Mobo:
http://www.novabilgisayar.com/bilgi.asp?ID=8474
Gpu:
SAPPHIRE HD7950 OC 3 GB, PCIExp, DirectX 11, DDR5, 384 bit, 950/5000 (11196-10-40G)
http://www.novabilgisayar.com/bilgi.asp?ID=8517
Ram:
GSKILL 8GB (2x4GB) RipjawsX DDR3 1600MHz CL9 1.5V Dual Kit Ram
http://www.vatanbilgisayar.com/Ram/gskill-f3-12800cl9d-8gbxl-8gb-(2x4gb)-ripjawsx-ddr3-1600mhz-cl9-15v-dual-kit-ram/productdetails.aspx?I_ID=51959
HDD:
WESTERN DIGITAL 1 TB SATA III HDD 64MB Caviar Green 6GB/s WD10EZRX
http://www.novabilgisayar.com/bilgi.asp?ID=4450
SSD:
CORSAIR 120GB F120 Force Serisi SATA III SSD CSSD-F120GB3-BK
http://www.novabilgisayar.com/bilgi.asp?ID=7535
Case:
IN WIN Dragon Slayer GAMING (2x 14cm Fan + 9cm Fan + USB 3) Micro ATX
http://www.novabilgisayar.com/bilgi.asp?ID=6579
PSU:
THERMALTAKE TR2 POWER 80PLUS 600W
http://www.vatanbilgisayar.com/Güç%20Kaynağı/thermaltake-tr-600pceu-tr2-power-80plus-600w-guc-kagnagi/productdetails.aspx?I_ID=53675
Again i'm sorry about the turkish sites, since i don't know if i can order single computer parts from newegg or amazon, i'm stuck with these two.
Again, sorry for double posting and since my bugdet is very limited - i'm not making much money right now.. - i wanted to be sure about the system that i'm gonna buy.
so Here it goes:
Cpu:
Mobo:
Gpu:
Ram:
HDD:
SSD:
Case:
PSU:
