My fairly older homebuilt kept conking out and turning off right after the post, and losing all video on the monitor. I had already eliminated the video card as a culprit. Next, I installed a new power supply (Corsair CX500, up from original 430 watts). Now I get nothing at all on the monitor, and two beeps at startup, but the fans keep on spinning. I unplugged and reconnected both the 4 pin and 24 connectors, same for hard drive, and switched and re-sat the memory. I also tried starting with the onboard graphics on the MB instead of the video card. Same two beeps, no video, but fans are powered up.
So, any suggestions on next steps? My four options seems to be:
-- Pull everything out of the case and rebuild it from scratch (but I feel I've practically done this)
-- New motherboard
-- New CPU
-- Both of the above
System now includes:
-- Corsair CS500 PSU
-- Asus P5LD2-VM motherboard
-- Intel Pentium D 820 LGA775 2.80 CPU
-- 2GB Memory (2x1)
Perhaps not even worth it, but I'm not ready to afford a new build, so want to get this computer up and running as inexpensively as possible (and fight the temptation to turn it into something more than it is).
Any suggestions or guesses greatly appreciated!
Thanks,
Larry
-- New motherboard
-- New CPU
-- 2GB Memory (2x1)
Thanks,
Larry
