Doing A New Build! Need Some Help, Please!!
So, I have my build, but is it okay? Do I need anything else? Do I need to make any changes?
Also, whats' better? A Sapphire Radeon HD 7870 or an ASUS Radeon HD 7870? Or should I go for something completely different like the NVIDIA GeForce 560TI?
My build is the following:
NZXT Phantom 410 Black/Orange Case
Corsair TXM 650W PSU
ASUS P8z77-V Motherboard
Intel i5 Core 3570k CPU
Cooler Master Hyper 212 Evo CPU Cooler
Corsair 8GB Vengeance [Low Profile] Blue RAM
Asus Radeon HD 7870 2GB
Samsung 830 128Gb SSD
Western Digital Cavair Black 1 TB HDD
Microsoft Sidewinder x4 Keyboard
NZXT Avatar S Mouse
Samsung S23B550VS Screen
Advice would be very much appreciated! Thanks!
7 answers Last reply
More about doing build help please
  1. Couple of suggestion: Get an ASRock Z77 Extreme4. The P8Z77-V is overpriced. If you buy the ASRock from Newegg in the US they'll toss in 8GB free RAM.
    Get a cheaper HDD. If it's not your OS drive performance doesn't matter much and the Blacks are overpriced.
    See if you can get a 7950.
    Hey, Thanks. I've heard alot about the ASRock Z77 Extreme 4, However, I've always had an ASUS Mobo, and they have never seemed to fail me.
    What HDD would you suggest?
    I would get a 7950, however, its a little too expensive. What would you suggest otherwise?
    Thanks.
  3. I assume you're in the US? Will find one.
    EDIT: Samsung Spinpoints are good & cheap: http://pcpartpicker.com/part/samsung-internal-hard-drive-hd103sj
    Nah, UK.
    Will look at that though :)
    Any help on Graphics card?
  5. They're both good. I wouldn't get the 560Ti. This is my advice if getting a 7870 (unless you can see one cheaper, PCPartPicker doesn't catch every deal) : http://pcpartpicker.com/uk/part/msi-video-card-r7870twinfrozr2gd5oc
    7950: http://pcpartpicker.com/uk/part/msi-video-card-r7950twinfrozr3gd5oc
    I'd consider all of MSI, Sapphire, ASUS, and Gigabyte.
    EDIT: Looking at HDDs, the Caviar Black is actually pretty cheap (50 pounds): http://pcpartpicker.com/uk/part/western-digital-internal-hard-drive-wd1001fals
    A slower 1.5TB drive: http://pcpartpicker.com/uk/part/seagate-internal-hard-drive-st1500dl003
  6. Ive read that the Sapphire 7870 is much cooler, and quieter than the ASUS 7870. Thats a big plus for me really. Really considering the Sapphire 7870 now.
  7. Really? The DCu cooler is generally one of the best I thought. You'll be happy with either though I expect.
New Build Systems Product
