Hello guys,
Long time reader, first time poster, it's also the first time I'm building a rig myself.
The computer will be used to play games only. I tend to uninstall games as i finish them. I'll be playing Fifa 13, WoW, Diablo 3, some heavy modded Skyrim and other open world rpgs and online stuff.
I intend to build this rig as an investment for the future.
I already have a 1920x1080 dell monitor, keyboard and mouse and speakers, so I won't need any of those.
I also have Windows 7 Home Edition, a HAF 922 case (not mine yet, getting it from a friend), a Corsair H100 cooler and a Corsair Tx850 V2 850w PSU, which I'll also be using.
My budget is somewhere around $2.500, and I ll probably get it all from newegg unless I can’t find it there.
I would like to get:
Intel Core i7-3930K, running at 4.5GHz or so;
ASUS Sabertooth X79 LGA 2011;
2x Mushkin Enhanced Chronos Deluxe 240gb which will run in raid 0, or no raid if I need space, they are only $165 on newegg;
G.SKILL Ripjaws Z Series 16GB (4 x 4GB), I ll only use 16 gb, no need of 32gb as I will use Win 7 Home;
Creative Sound Blaster Recon3D Fatal1ty Professional; and
2x EVGA 04G-P4-3688-KR GeForce GTX 680 Classified 4GB, these go for $559 on newegg, I will run them on SLI.
My questions are:
1. Is this all compatible? I hear some ssds have some compatibility issues.
2. Will it fit? I know the HAF 922 is not that big and read that the GTX 680s are also kind of big, will the 2 of them fit inside? there's also the soundcard in there. What about the H100 will it fit the HAF 922 case? Some people have problems with that.
3. Will it be cool enough? I only intend to overclock the CPU, no need to overclock the GPUs, but I know they run hot in SLI.
3.1. Will the corsair H100 keep the i7 i7-3930K cool enough if it runs at 4.5 GHZ?
3.2. Do I need extra cooling for the GPUs? I hear evga push the hot air outside the case and I won't overclock them at the beginning at least, so will they run cool enough or should I try something else?
4. A 850w PSU is enough for setup? the GPUs use 550w.
Open for suggestions, critics!
My questions are:
