A friend of me have an old computer with a Asus Motherboard P5N-E and a intel core 2 quad 6600. Its the boxed intel fan on it, and it also got two cabinett fans (small). When idle the tempratures in cpu z hardware monitor says around 55 - 60 degrees celcius. I tought that was high? I know he had some shut down problems in the past due to heat problems. I have used air to clean the fans, so its clean from dust. But still the high temp.
I dont think he want to spend any money on getting a better cpu cooler, the computer is only used for some web and excel work. So i was thinking about maybe trying to downclock it? Is this possible ? Its 2,4 ghz now. I would not think he would notice if i downclocked it to 2 ghz? Would it be better for the temp problem or will it stay the same?
If it would be better, can sombody tell me what values i need to change in the bios to get it downclocked, so I can give it a try.
