Solved
Very basic HTPC GFX card help
Ive got an old LGA 775 dell board & processor ( 3.2HT) and i wanted to make an htpc out of it, for now atleast... What GFX card should i use play 1080p X264 from HDD and mabye some n64 emulations.... I am open to all suggestions and comments... THX for all ur help...
-Jeff
4 answers Last reply Best Answer
More about very basic htpc card help
  1. The HD7750, tiny amount of power draw (doesn't require any power cables) and should be decently powerful for light/med gaming.
    Suspect the N64 emulator will be constrained by the CPU before the graphics card.
  2. a pci 3.0 card in that low spec of a system... not doubting you.... just bewildered that that would be an option...
  3. Best answer
    Any modern card will be PCI-3, it itself is not an indicator of performance.
    You could go even lower and get something like a 6670.
    Sapphire 6670. $65 ($15 rebate)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102988&name=Desktop-Graphics-Cards
  4. Best answer selected by j3tw4v3.
New Build Processors Basic Systems Product
