since i saw an alienware X51 which is small factor gaming pc, i have a lot of question in my mind.
building a pc with XBOX 360 case is also possible but without a graphic card which is not declare as a gaming pc.
using alienware x51, it has an external power supply just like Xbox 360. but when building your own with this case, where will you put your 800W gaming psu? externally will make your building harder cuz most of power supply's cord cannot be pulled out from the psu itself. standard gaming psu are atx type. same goest to xbox 360.
this guy http://forums.bit-tech.net/showthread.php?t=224593 able to install graphic card to the xbox 360 case with PCI-E x16 Riser Flexible Cable. but, the graphic cad is too big for xbox 360 (hd 4870).
now, i have 30cm X 25cm X 7.5cm case which is unused later. its a dvr in which will later reach its age. so im going to use that case later for my diy pc building. but how about psu?
with appropriate tools and skills, do you think that this diy pc can be make?
cpu: unknown (maybe at least amd athlon X2 260. if possible, AMD FX-4100)
mobo: micro-atx ASRock N68C-GS FX (which is the cheapest yet smaller, better mobo available in my area)
gpu: at least hd 7750 small profile (heard hd 7750 performs nice even small profile one)
psu: at least 300W with 6-pin power connector @ 12V X 20A
cooler: stock if possible. but smaller is better
ram: 2X 2GB ddr3
optical drive: well, not necessary for me when goes to small case. but laptop size one is perfect
hdd: 2.5" hdd with at least 320GB
extra fans: 1X 180mm fan ONLY IF required
the case will be mod. NOTE THAT im NOT REALLY PLANNING TO DO THIS. but maybe be planned in future when my dvr is not capable anymore.
ram: 2X 2GB ddr3
