Hi everybody, I was wondering if y7ou could give some advice on this build of mine and please don't say any intel processors they are too expensive for my build. This build will be primarily used for gaming.
Here are my components:
Western Digital WD Green WD10EZRX 1TB IntelliPower SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
HIS IceQ X H785QN2G2M Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
SeaSonic M12II 520 Bronze 520W ATX12V v2.3 / EPS 12V v2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
ASUS Black Blu-ray Drive SATA Model BC-12B1ST/BLK/B/AS - OEM
BIOSTAR TA970XE AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
AMD FX-6200 Zambezi 3.8GHz (4.1GHz Turbo) Socket AM3+ 125W Six-Core Desktop Processor FD6200FRGUBOX
Alright, right now I could really use some recommendations on some cheap, 19''-21'' inch monitors that would be good for gaming and if I used 2 of them at the same time.
Thanks,
Elite
Thanks,
Elite
