floppy problem??
Forum CPU & Components : Other Components - floppy problem??
I've got a problem with the floppy drive. I've build a system last night and floppy led is on all the time, windows explorer can't reach to a:...I've changed the cable orientation but this time the bios gives alarm. What's the problem?
Best Regards.
Sponsored Links
Double check you haven't bent a pin.
<b><font color=blue>~scribble~</font color=blue></b> :wink:
Reply to camieabz
Have you tried the drive in another system?
Rob
Please visit <b><A HREF="http://www.ncix.com/canada/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/canada/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
you pluged in the data cable backwards
Blame the newbies not the technology
Reply to AMD_cErTiFiEd
Hello
I have this problem on 2 computers, one was buiilt last year and developed the problem about 2 weeks ago, I noticed but didn't hink abotu it much. The other was an old system that was rebuilt and now has it. The led comes on as soon as the PC is turned on. If a disk is inserted then the drive just spins so no I?O can happen.
It is not the cables in my case IMHO as they haven't moved from when the drives were working.
Thank you in advance.
Mr Blonde
Reply to Anonymous
Pull the drives and stick them into a system that works. That will eliminate one possibility.
I have found that after 3 years or so, FDDs can just go without warning.
Reply to camieabz
Hello.
I have checked the drives in other systems and they work, I also put a drive from an old machine that works into my systems and it has the same problem, the light is on even before POST, so it is always on.
Could it be the north or south bridge on the mobo failing, or could it be the PSU?
I tried two floppys on the floppy cable and then they both get the problem.
Mr Blonde
Reply to Anonymous
Why do you need a floppy anyway?
Reply to JCLW
Doh. Maybe because some new hardware, and alot of old comes with the drivers on floppys, maybe because he uses it for work, letters and stuff, bringing them from work or viceversa. they are also usefull for bootdisk's!
Let me ask, do you have dvd? if so, why dont you dump your cd-rom. Get the picture.
Reply to Anonymous
Sorry, I didn't mean to upset anyone...
but you have to admit floppy disks are ancient technology. I find it interesting that everyone still uses a 1.44mb disk instead of moving on to a newer technology like 250mb Zip disks or the LS-120s.
Reply to JCLW
Hey man. Either you got bad Floppy drives or you've got the floppy ribbon cable reversed at either the floppy drive end or the floppy connector on the motherboard. Double check the cables and make sure the red wire is in line with Pin 1. Pin 1 should be printed in white next to the floppy connector on the motherboard. Hope this helps.
Reply to TNC10284
Tom's Hardware > Forum > CPU & Components > Other Components > floppy problem??
There are 1214 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
