Hi all,
Looking at setting up rais 0 on my system, have currently 1 40 gig ibm 7200 in there, will get another of the same, board is abit kt7a raid, and thats the raid controller I will be using, have a couple of questions.....(erm havnt read the manual as im at work - meant to bring it but forgot- and want to buy the hdd on the wqay home)
1. How much performance increase will I see (please answer ony if you have done it)
2. Do I set the drives to master/slave or what, di they go on one channell or one on each
3. Can I keep the data on my current drive or will it be zapped?
4. If I decide its not worth the hassle, can I go back to just one drive without data loss ?
5. any other advice welcome
Thanks
Next time you wave - use all your fingers
Thanks
