Hello,
I'm new to these forums, and I'm looking for a bit of critique on a budget gaming pc I plan to build in the near future. I'd also appreciate a recommendation for a quality PSU and an affordable ATX mid tower. Style is not an issue, but I'd like to get something with a simple design and adequate airflow. Feel free to comment on or criticize any component I've chosen, because I'm trying to learn and I'd like to not get stuck with low quality just to save a few bucks.
Approximate Purchase Date: possibly next week
Budget Range: <$800 before rebates/shipping
System Usage from Most to Least Important: gaming (will spend a lot of time on Skyrim), maybe Netflix
Not purchasing a monitor
OS: Planning on Windows 7 Home Premium 64 bit
Preferred Website(s) for Parts: Tiger Direct, Newegg, maybe Amazon, also open to suggestions
Parts already found (could be convinced to change my mind)
CPU: AMD Phenom II x4 965 Black Edition
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5312392&CatId=4431
GPU: MSI R6850 Cyclone PE Radeon HD 6850
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1318423&CatId=7005
Mobo: GIGABYTE GA-970A-D3
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1963432&CatId=7248
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314&name=Desktop-Memory
HDD: WD Blue WD2500AAKX 250GB Hard Drive - 3.5", SATA, 6Gbp/s, 7200RPM, 16MB Cache
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=160418
SSD: Kingston SH103S3/120G HyperX 120GB Solid State Drive
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2416662&CatId=5300
Some recommendations here would be very helpful:
DVD-ROM: ?
Case: ?
PSU: ?
Overclocking: No, but maybe in the future.
SLI or Crossfire: No, but maybe in the future.
Monitor Resolution: I will be using a 1080p HDTV 32"
Additional Comments: Like I said, appearance is not key, and I'm trying to keep the price below $800, so please comment and I will be eager to read what you have to say.
DVD-ROM: ?
Case: ?
PSU: ?
