I built my first computer four years ago. It worked great, but I think it is time for an upgrade. I need help figuring out what parts I need to replace, and if the replacement parts I have picked work together.
Here is the computer I built four years ago.
1 x Logitech Deluxe 250 Black USB Wired Standard Keyboard - OEM
1 x Western Digital WD Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 x Acer AL2216Wbd Black 22" 5ms Widescreen LCD Monitor with HDCP support
1 x Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G - OEM
1 x LITE-ON 20X DVD±R DVD Burner Black SATA Model iHAS120-04 - OEM
1 x RAIDMAX SMILODON Extreme Black ATX-612WEB 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case
1 x Foxconn P45A-S LGA 775 Intel P45 ATX Intel Motherboard
1 x MSI R4850-512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
1 x OCZ GameXStream OCZ600GXSSLI 600W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
1 x Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor BX80570E8400
1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D
Here are the parts I am considering buying for replacement.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=25527007
Here are my main questions.
1. Do I need to replace my RAM? I have 4 x 2 gigabyte sticks now. Are they still good after 4 years? Or should I buy the 2 x 4 gig sticks in the wish list.
2. Do I need to replace the power supply?
3. Will these components work well together? If there are any parts I went too high or too low on, please let me know. I plan on using this for gaming, but nothing extreme. I don't really plan on overclocking or messing around with too much.
4. Is it fine to just get the 120gb ssd drive? My plan is to put my OS and games I play a lot on the SSD. I would then have my 4 year old 640gb and 2 year old 1 tb drives for lots of storage.
Thanks for your help. Let me know if I forgot to include any essential information.
