Built a new system about a month ago, budget gaming build. It's been great until now. Here's a partial dump of the Newegg order:
CPU: Intel Core i3-2100 Sandy Bridge 3.1GHz LGA
Mobo: MSI Z77A-G45 LGA 1155 Intel Z77
Case: APEVIA X-JUPITER-JR S-Type X-JPJST-MG, with a single 250mm side-mount fan
PSU: Raidmax Hybrid 2 RX-530SS 530W ATX12V V2.2/ EPS12V
GPU: Gigabyte GV-N660OC-2GD GeForce GTX 660 2GB
RAM: Kingston HyperX 8GB (2 x 4GB)
HD: Samsung Spinpoint F4 HD322GJ/U 320GB 7200RPM
Playing Battlefield 3 the other night, the machine suddenly reboots itself. Start the game back up, play a few minutes, it does it again. I start to look into possible causes and find the following:
1) GPU running too hot. So I ran GPUZ and logged temps, they're steady at ~60C when the reboots occur. Check, that's not it.
2) Drivers suck. I found my driver was out of date, so I updated and tried again. Beep, reboot. Not it.
3) PSU is bad, or insufficient. Haven't eliminated this but I can't imagine I'm drawing that much power; it's a Raidmax 530W. The GTX 660 is relatively efficient at 140W max draw; GPUZ showed that it was peaking at 100% (not overdrawing, if that's even possible).
Another important piece of info: yesterday the machine rebooted itself again, while I was scrolling through a PDF or working in Wordpad or something and the GPU was hardly doing anything. So that implies that my PSU providing insufficient power isn't the problem, and that either:
A) the PSU just sucks and the power is fluctuating enough to cause reboots, or
B) something else is wrong entirely.
Thoughts?
Thanks
Thoughts?
Thanks
