$800 BUILD. Please Help.
Approximate Purchase Date: Tonight!
Budget Range: $600-$800
System Usage from Most to Least Important: Gaming, Everything else
Are you buying a monitor: No
Parts to Upgrade: Need everything EXCEPT gpu, hard drive, and operating system.
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com, amazon.com, tigerdirect.com
Parts Preferences: No preference
Overclocking: Yes, Small Overclock. Air Cooling Only.
SLI or Crossfire: Possible
Your Monitor Resolution: 1680x1050
Additional Comments:Current PC is too loud. Would like something quiet but don't want to spend too much on a case or cooling. Would prefer to spend the most money on the CPU.
I am reusing my current GPU which is a geforce 570. Reusing an old HDD and SSD. Will not require an OS.
Why Are You Upgrading: My current system is starting to show it's age.
9 answers Last reply
More about build help
  1. What is your current system?
  2. Giving my current system away. It's an older Core 2 DUO. With 4 GB DDR-2 Maxed Ram.
  3. PCPartPicker part list / Price breakdown by merchant / Benchmarks
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($214.99 @ Newegg)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.82 @ NCIX US)
    Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Amazon)
    Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
    Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($49.99 @ NCIX US)
    Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.49 @ SuperBiiz)
    Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($91.99 @ Amazon)
    Total: $576.26
    For gaming this is all that is necessary. Anything more expensive is not going to have a cost effective benefit.
    Total: $576.26
    I don't need an OS. I do however need a case. You did not mention one.
  5. Quote:
    Here you go.
    PCPartPicker part list: http://pcpartpicker.com/p/l7L5
    Price breakdown by merchant: http://pcpartpicker.com/p/l7L5/by_merchant/
    Benchmarks: http://pcpartpicker.com/p/l7L5/benchmarks/
    CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($314.99 @ NCIX US)
    Motherboard: ASRock Z77 Extreme6 ATX LGA1155 Motherboard ($179.99 @ Amazon)
    Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1600 Memory ($61.99 @ Newegg)
    Case: Antec One ATX Mid Tower Case ($39.99 @ NCIX US)
    Power Supply: OCZ Z Series Gold 1000W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($99.99 @ NCIX US)
    Optical Drive: LG GH24NS90 DVD/CD Writer ($15.99 @ Newegg)
    Total: $739.76
    Has room for all the parts you already have. Since your sticking with an older gpu i gave you the juice to go for sli 2, 3 or even 4 times if your card supports it so you can snag them on the cheap as they start to dry up and upgrade your beast further.
    What type of advantage will I see running an I7 vs an I5? ..
    If I do end up running an I7 I don't think I need motherboard that fancy. I can't imagine going over 2 cards in my system.
    Are all I7 boards that expensive or is their a specific reason you chose that one?
  6. No, you don't need an i7 for gaming. You'll only need it for CPU-heavy or multithreaded tasks. Go with the i5-3570k.
    Will you be buying a new monitor soon? There's no point in SLI/Crossfire with your resolution.
    You can drop the motherboard to an Extreme3 or 4. Depending which has a better deal at the date of your purchase.
    I'm on mobile atm and it's sorta a hassle to look for links but here are some things to look at for casings.
    Rosewill Challenger-U3
    Rosewill Blackhawk
    Cooler Master HAF 912/922
    Antec Three Hundred Two
    Rosewill Blackhawk
    I may some day upgrade to a higher resolution/larger monitor. And that's why I want the ability to crossfire. And the date of purchase is tonight. As soon as I make my mind up.
    If the budget can handle, try to get a 120Hz monitor to get the most out of the SLI 570s.
    The Extreme4 is Crossfire-ready, it'll be perfect for you.
    Make sure to get enough PSU wattage so you won't have to upgrade anymore when the time comes that you add the 2nd GPU.
New Build Systems Product
