Solved
Will this RAM and this MOBO work together?
Will these two things work together? I noticed the mobo supports "1333+" , and the RAM is 1866. Here are the links MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128564
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148559
Thank you for the help
4 answers Last reply Best Answer
More about will mobo work together
  1. Best answer
    yep your good
  2. The best is to get the RAM that is specified in the vendor list.
    http://www.gigabyte.com/products/product-page.aspx?pid=4208#sp
  3. i see what you mean but he is fine with just that ram, it fits its 2x240pin and the ram is... 240pin so he is fine
  4. Best answer selected by ArcticWonder.
Homebuilt RAM Systems
