Is my PSU capable of running high end graphics cards please help
Graphics Cards
Graphics
Tom_100
August 27, 2012 10:32:19 PM
I have an assembled pc having the following spec:
Processor: iCore3 2100 3GHZ
Motherboard: Intel DH61WW
RAM: 8 GB DDR 3
PCIE x16 version 2.0 slot card : xfx 9400GT 1GB
Hard Disk : 1 TB Western Digital SATA
DVD Writer
MY 500 Watt PSU has got two 12V rails as printed on the side of the PSU's cover
+12V1 => 22 A
+12V2 => 22 A
(If you need other voltage or ampere values printed on the side of the PSU, please let me know)
And 1 PCIE 6 Pin connector ( 6 pin + optional 2 pin ) - wattage of this connector is unknow to me.
Can I run any of the following cards without upgrading my PSU and damaging any of the existing components ?
HD 7750, HD 7770, HD 6790 , HD 6850, GTX 550 ti, GTX 560, GTX 560 SE, GTX 560 ti
RAM: 8 GB DDR 3
DVD Writer
+12V1 => 22 A
+12V2 => 22 A
More about : psu capable running high end graphics cards
Tom_100
August 27, 2012 10:54:32 PM
- pls suggest me a graphics card that is capable of running bf4 and other modern shooters on high settings - Forum
- would this aerocool psu support a high end graphics card? - Forum
- Is this system capable of running dual graphics cards? - Forum
- Graphics running slow on high end card! - Forum
- is it okay to run high end graphics card on a low resolution ? - Forum
According to the Specs of your power supply you should be able to run any graphics card that requires no more than 1 PCIe power connector. However, as others have stated, we have no way of knowing whether your PSU actually supplies the current and wattage that it is rated for. Tell us the brand and model number of the PSU and then we can look it up and make a better assessment of it's quality.
Score
variokas
August 27, 2012 11:06:13 PM
Tom_100
August 27, 2012 11:12:10 PM
It is a local brand -
E-Spectrum - model: ES - PSU - 500 W
This is their website: http://www.e-spectrum.in/
My model is not listed in the website. Instead there is another 500 Watt model on display -
http://www.e-spectrum.in/products/power-supply/es-psu-p...
Hope this helps.
EDIT: The model on display in the website is the same as my model. Only difference is that my 12V rails have 22 A instead of 20 A
Hope this helps.
Score
Tom_100
August 27, 2012 11:18:17 PM
Tom_100
August 27, 2012 11:48:18 PM
Will brands like - Cooler Master or iBall work as an alternative ? If so which models ?
Secondly - I see that crossair CX600 has a extra fan on it top (in the picture).
http://www.corsair.com/builder-series-cx600.html
Will it fit into my existing cabinet or do I have to buy a new cabinet too ?
Score
KaiGaming
August 28, 2012 6:52:36 AM
Tom_100
August 28, 2012 9:50:16 AM
If I can use HD 5770/6770/7770 with my existing PSU. Then why not HD 7750 ?
Secondly , do the rear end of the top cover of the cabinet needs to be open to allow air flow from the cross air PSU CX 600 which has a fan on the top as shown in the picture - http://****/api/click?format=go&key=984ed3ed6aa9a69986f88d56d10e7616&loc=http%3A%2F%2Fwww.tomshardware.com%2Fforum%2F367683-33-capable-runnin...
Score
KaiGaming
August 28, 2012 9:56:25 AM
Tom_100
August 28, 2012 10:04:25 AM
Here is the link for the picture of crossair PSU - http://www.corsair.com/builder-series-cx600.html
Score
Raid Z3ro
August 28, 2012 10:11:15 AM
Tom_100
August 28, 2012 10:18:18 AM
Can you guys confirm if I buy this model of crossair CX 600 - http://www.gadgets.in/corsair-builder-series-cx600-cmps...
Will I be able to run any of these cards without any worry ?-
Score
Tom_100
August 28, 2012 10:19:06 AM
Tom_100
August 28, 2012 10:19:33 AM
Tom_100
August 28, 2012 10:37:09 AM
Sunius said:
Yes, CORSAIR is a decent choice and it will work with either of those cards. I personally have it powering up my GTX 560 Ti.Are you using this model - http://www.corsair.com/builder-series-cx600.html
Or can you confirm if this model is good enough for running gtx 560 ti ?
Score
hellboy11
August 28, 2012 11:07:22 AM
hellboy11
August 28, 2012 11:19:17 AM
Tom_100
August 28, 2012 12:34:11 PM
Tom_100 said:
Are you using this model - http://www.corsair.com/builder-series-cx600.htmlOr can you confirm if this model is good enough for running gtx 560 ti ?
Yes, that's the exact model I have.
Score
Tom_100
August 28, 2012 10:47:05 PM
Not really.. If you game 10 hours a day EVERY DAY, it will use 50 kWh a month. Not sure how much you pay for one kWh, but I pay $0.15. So the card would cost me just under $8 every month if I played 10 hours a day every day.
Though that's far from realistic estimation, because I personally don't game that much
. Score
amuffin said:
Cooler Master does not make PSU's
What?
http://www.coolermaster.com/category.php?category_id=22
Stack of product lines . . .
Score
Tom_100
August 29, 2012 5:37:09 PM
Depends on series.
http://www.tomshardware.com/reviews/power-supply-oem-ma...
Only those made by FSP are good from coolermaster portfolio.
Score
Tom_100
August 29, 2012 7:00:02 PM
Tom_100
August 29, 2012 7:28:06 PM
Sunius said:
Depends on series.http://www.tomshardware.com/reviews/power-supply-oem-ma...
Can you please tell me the correct formulae of calculating the total ampere available in 12V rail when there are dual 12V rails of 22 Ampere each ?
Score
Tom_100
August 29, 2012 8:05:50 PM
Tom_100
August 29, 2012 8:14:15 PM
Tom_100
August 29, 2012 8:18:25 PM
Tom_100
August 29, 2012 8:46:14 PM
You can upload it to www.imageshack.us, just select "Do not resize" option.
Score
Tom_100
August 29, 2012 9:14:31 PM
Sunius said:
You can upload it to www.imageshack.us, just select "Do not resize" option.Ok. here you go. You may download and zoom to get a close look.
http://desmond.imageshack.us/Himg696/scaled.php?server=...
or
http://imageshack.us/photo/my-images/696/psuspec.jpg/
Score
Well, since you have 400W total, 24A goes to 5V and 18A goes to 3.3V, the rest goes to 12V. So 12V power = 400 - 24*5 - 18*3.3 = 220.6. Divide that by 12 and you'll know total amperage for 12V rail.
220.6/12 = 18.3A.
So yea, that's what you get from chinese manufacturer. I'd not use that power supply with a discrete card, the sticker is lying.
220.6/12 = 18.3A.
Score
Tom_100
August 29, 2012 9:24:04 PM
Sunius said:
You didn't post a link to it...Sorry, I am doing it again -
or
Score
Tom_100
August 29, 2012 9:29:53 PM
Sunius said:
Well, since you have 400W total, 24A goes to 5V and 18A goes to 3.3V, the rest goes to 12V. So 12V power = 400 - 24*5 - 18*3.3 = 220.6. Divide that by 12 and you'll know total amperage for 12V rail.220.6/12 = 18.3A.
Oh ! So HD 7750 will unable to run on ~ 18 A 12V rail current ?
Tell me something more. Will a crossair CX 600 or cooler master 600 W fit into normal normal tower cabinet or do I have to get special type of cabinet for them ?
I am asking this because unlike normal PSU the cooling fan for cross air or cooler master is on the top instead of on the rear side.
Score
Don't get cooler master. They aren't good either. Get a Corsair one.
And the fan is on the bottom, not on the top. It will fit inside normal case easily.
And HD 7750 should be able to run on it, but I wouldn't push it. These kind of power supplies can only cause trouble - around a year ago chinese power supply almost ignited my curtain - I was lucky to see the flames in time and more the PC away from the curtains.
Score
Tom_100
August 29, 2012 10:35:08 PM
Sunius said:
Don't get cooler master. They aren't good either. Get a Corsair one.And the fan is on the bottom, not on the top. It will fit inside normal case easily.
My God. Now I am in real trouble. The local store said that they will only be able to provide iBall and Cooler Master but no Cross Air !
Moreover I have only managed to gather money good enough to buy HD 7750 and GTX 550 Ti. Out of this two, it appears that only HD 7750 is fit enough to that PSU capability. Those PSU will take up nearly the price of HD 7750 ! I am really stuck.
Whether to go with HD 7750 without an upgrade or borrow money for the PSU. HD 7750 does not give a requirement for the ampere in +12V rail. It only says it needs a 400 Watt
PSU. See here - http://www.amd.com/us/products/desktop/graphics/7000/77...
And mine says regular 400 Watt and peak 500 Watt. Question is can the PSU perform when the HD 7750 is drawing ampere under peak load of around ~ 50 Watt. I hope HD 7750 won't go over 50 Watt under peak load.
P.S If the fan is at the bottom then it is a real problem. How come they put the fan at the bottom ! The whole hot air will circulate inside the chassis / cabinet and most importantly the hot air will blow pass the processor ! What a design ! It will heat up all the components inside the cabinet more !
Score
Tom_100
August 29, 2012 10:37:17 PM
- 1 / 2
- 2
- Newest
- Solved2 graphics cards, one running please help! Forum
- Solvedcan a low end graphic card run high end games? Forum
- SolvedLooking for a top end graphics card - please help! Forum
- SolvedBest 1440p Gaming High End Graphics Cards 2014 Forum
- SolvedHelp please. Graphics card trouble, ( at the end of my tether) Forum
- SolvedHelp me decide on a high-end graphics card Forum
- Need Help Determining Best Fit Graphics Card for my VERY High End Custom Built Desktop Computer Forum
- SolvedHigh end vs low end graphics cards? Forum
- SolvedDo I need high end graphics card for AUTO CAD Forum
- SolvedDoes the processor matter on high end Graphics cards? Forum
- SolvedHP Z400 graphics card (high end) needed Forum
- SolvedDo you really have to buy high-end graphcis cards? Need help with this build... Forum
- SolvedWill my PC run high end next gen games with slick and clean graphics? Forum
- Solvedhigh end graphics cards Forum
- SolvedNew High-End Graphic Card - NVidia GTX 980 Forum
- More resources
