ASUS M4N78 Pro
amd Phenom II X4 955 Black Edition 3.2GHz AM3
COOLER MASTER Hyper 212 Plus
Thermaltake Purepower W0129RU 600 W
went to boot cp up, it said cpu fan not working, sure enough its not working. the cpu is a year and 2 months old.
so i buy the cooler master hyper 212 install it, it boots up no problem. so i shut down because i have to work.
last night, second time booting up with the hyper 212 installed, it says cpu fan not working.
so im guessing my motherboard cpu fan connector is bad, but is there an adapter to run the cpu fan without using the cpu fan connector on the motherboard?
is there a way to test the hyper 212 fan to make sure it is in working order and not in need of a return?
