Hi, I am in the process of building my first PC. I have lots of questions. These are the components i have picked out:
(parts with "X's"- I have already purchased.)
Case: (X)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
MB: (X)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
PSU: (X)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Ram: (X) [2]
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233218
Disk Drive: (X)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151258&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=6146836&SID=b8s5f2j3cse6
CPU: (?)
I dont really know much about processors, but i think i want an i7 so i wont have to upgrade the computer as tech evolves. I would like it if someone could point me to a high quality one that goes with my MB and is under 375
GPU: (???)
I really don't know anything about GPU's, i want to spend 200-350 on one. I would like to play on high or ultra so if that is possible with my budget please point me in the right direction.
Cooling: (?)
I know a little bit about cooling, but not much. Currently i am using only the stock things for cooling that come with my case. I've been told that is bad. what extra fans do i need to run my PC efficiently? Also I've heard about Liquid cooling, is it a easy thing to do? (note: this is my first build and take in account my case) If so what necessary steps should be taken in order to make it a liquid cooled PC.
OS: (what do people think?!?)
Ok... so ive been hearing a lot about Windows 8, mostly bad. I would like to stay in the loop with the latest and greatest tech but people say 8 sucks. Is windows 8 just a change that people dont want to make or is it like Vista (AWFUL)? This computers primary focus will be gaming so keep that in mind.
I know I have a lot of questions but please help me, I want to make sure everything is good for the build. So if there are a problem with the components please tell me so.
-Thank you 4 the feedback
Case: (X)
MB: (X)
PSU: (X)
Ram: (X) [2]
Disk Drive: (X)
CPU: (?)
GPU: (???)
Cooling: (?)
