Case and cooler help
  • Power Supplies
  • Cases
  • Cooling
  • New Build
  • Components
Last response: in Components
March 7, 2013 11:45:04 AM
im saving up for a new build the case will be the 800d and the cooling will be the h100i. the 800d fans on top are 140mm big while the h100i the fans are 120mm big. how would i install the fans and which size should i get?
More about : case cooler
March 7, 2013 7:52:40 PM
My buddy modded his case to have the rad outside of the case and attached it to the back of his case. You could consider modifying your case yourself to accommodate :D
its fun!
m
l
