Do I need more power?
  • Power Supplies
  • Graphics Cards
  • Components
  • Product
Last response: in Components
March 7, 2013 5:39:04 PM
Hi,
Thanks for taking the time to help me today! :)
I am upgrading my motherboard, ram, and video cards, and need to know if i need a better power supply.
Current PSU: Ultra LSP 650w PSU
My new board: ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
New Ram: G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C8D-16GTX
New video cards:
2x: HIS H679F1GD Radeon HD 6790 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (with crossfireX cable)
Currently:
One Asus DVD burner
One OCZ vertex 4 128gb SSD
One 2tb WD Green 3.5" drive
one 1tb Wd black 64 mb cache 3.5" drive
AMD Phenom X4 965 Black Edition (not overclocked)
Nocturna aftermarket cooler (AM3)
More about : power
a b ) Power supply
a c 80 U Graphics card
March 7, 2013 5:46:10 PM
I would get a better power supply. That one doesn't have much 12v amperage compared to a quality corsair or seasonic would. Also why 6790's? Those are quite outdated at this point.
m
l
March 7, 2013 5:48:01 PM
It seems that you have enough power for your build, I don't think you will need to worry.
http://support.asus.com/powersupply.aspx
Try the link, since you are the one who knows what will be plugged in at all times. But it is wise to avoid the budget cheap brands since they are not very good. Try Seasonic, Corsair, XFX.
(Note this is the Minimum Recommended amount, try to have about 50-100 more watts)
m
l
March 7, 2013 6:08:07 PM
Well i was running a single EVGA 512MB 9800 GTX and a friend sold me 2 of these both for 100 bucks, so I couldn't pass it up, and the only games I play are diablo 3 and dirt 3 for now.
m
l
March 7, 2013 6:09:02 PM
m
l
a b ) Power supply
March 7, 2013 6:19:09 PM
That is a nice PSU. I have the original version and it has been great. $100 for both cards was a steal. Just wanted to make sure you weren't buying them new. :D
m
l
