Oiling Lian Li PC-P50 Case Fan
Last response: in Components
- Lian Li PC-P50 case questions - Forum
- Does Li W-LM2AB-1 panel fit Lian-Li PC-P50 or PC-P50R (armorsuit) ? - Forum
- Lian Li Armorsuit PC-P50 vs. Fractal Designs Define R3 - Forum
- 2 x 120mm Lian Li V1000 case fans (plus PCU fan) enough for SLI? - Forum
- Fan controller for Lian-Li case with 8 noisemakers - Forum
- Removal of interior fan from Lian-li case Forum
- How well will a psu with a 120mm fan work in a Lian Li case? Forum
- Lian Li Case: Replacing fan - little plastic connectors Forum
- Lian-Li PC60U case fan question Forum
- Help with Case fans on Lian-Li PC-60PlusII Forum
- Lian-Li Front Case Fans Forum
- SolvedCorsair H100i on a Lian-Li K62 case? Would it fit? Forum
- SolvedPSU facing in a LIAN LI PC-V354B case? Forum
- SolvedRe-using an older Lian Li case Forum
- SolvedMSI GTX 760 ITX and Lian-Li case compatibility Forum
- SolvedI have a question about the lian li q07b case. Forum
- Which Lian-Li Case? Forum
- Lian Li TR-5B - Digital 5.25” LCD Thermometer / Fan Controller - Black (TR-5B) Forum
- Solvedlian li case compatability? Forum
- SolvedLian Li pc-7fn fan does not spin Forum
- More resources
Read discussions in other Components categories
. I can't figure out how to get to the bearing. Although there is a little indentation / plastic circle directly over the bearing that looks like it may be able to be taken out, I don't actually think it can be.. any suggestions? Do I have to completely take the fan off the case (which involves completely removing my CPU from my MB, and possibly the MB itself?
