Help me pick a build
Last response: in Systems
malbluff said:
Personally, I'd say a mix of both.
CML RAM
Samsung SSD
Gigabyte GPU.
thanks for the information and I just can not decide on what to go for and also I think I should of stated that I will overclock the CPU and I am thinking of upgrading in the future SLI
Related ressources
ok thanks guys this has helped me to select the parts that I need and I did favour the 2nd build anyway :)  but this has made it clear that I should change my ram and I will then select that case unless the price increases on it.
thanks guys!
thanks guys!
If you can't get the 300R I would suggest the Antec 300 Illusion or the Fractal Design Arc MIDI.
Ask the community
