Previous Post :
New Update: Right, having the same problems again.... When I am currently on the beta driver and then roll it back to 301.42, it lags after the reboot, but before the reboot its fine. The same applies to when I am on 301.42, my game lags, then I update the driver to a beta and its fine (before I reboot) , then I reboot again and its all laggy ???
So basically, I know that only when you reboot does the new driver take effect, but what takes effect before the reboot because thats when something seems to happen and change the GPU performance....
Hi, I have an ASUS GTX 560ti gpu and I get a really weird problem and I am wondering if anyone could help or if anyone else has this problem, I install the latest beta driver (304.79) and then go on a game and it runs it perfect, then.... when I reboot my computer I go on the same game and it lags and runs poor. The exact same driver is installed (304.79) and my computer has the exact same nvidia control panel settings after the reboot.
It seems when I reboot, something happens to the driver to cause poor performance, but its perfect before the reboot with the exact same settings, its very strange, any help etc would be great, thanks
Computer Specs If Needed :
Processor: Intel Core i7 2600k S1155 8MB 3.5ghz (Currently overclocked to 4.5ghz)
Graphics Card: ASUS Nvidia Geforce GTX 560 Ti 900MHz PCI-Express HDMI (Overclocked Version)
Motherboard: Asus P8Z77-V LX Socket 1155 VGA DVI HDMI
RAM: G-Skill 8GB (2x4GB) DDR3 1600Mhz Ripjaws X
CPU Fan: Corsair Hydro Series H60 High Performance
Power Supply: Corsair 600W CX Series V2 PSU - 6x SATA
