Solved
Nvidia geforce gtx 550 ti problem
Hello,
i recently purchased a new computer at bust buy (ASUS CM6730) and a graphics card (PNY XLR8 Gtx 550 ti) and was ready to game. I installed the card and got no display. The power was on, the fans were spinning, i heard the hard drive start up, power to the mouse and keyboard, everything was normal, except the display. There was nothing. Thinking that it was the psu, i purchased a new one (thermaltake TR2-600w) and threw it in there and had the same problem. With the power pluged into the card, not even the onboard graphics would display. I unhooked the card, changed the bios, reinstalled it, and still no display. Im using the HDMI output, could this be the problem? Can anyone help me figure this out?
Windows Home 7 Premimum (64 bit)
Intel i5 2320 3.00 GHZz
6gb Ram
1Tb hdd
Best solution
The PSU should power that fine, but seeing as you pretty much did everything I would have suggested I don't know. It might just be a bad card. Can you try it in someone else's computer?
Resetting CMOS sometimes helps.
Ask the community
