Ati radeon HD 4870x2 one gpu problem
  • Graphics Cards
  • GPUs
  • Radeon
  • HD
  • ATI
  • Graphics
August 29, 2012 3:33:49 PM
http://www.youtube.com/watch?v=GIpZwmLJL4M
this is my problem. no graphic after this. i tried to use different graphic card and it work fine.
http://imgim.com/5961inciq7878761.jpg - here it needs to be show 2 4870x2 but i have only one. i think i gpu is not working ?
anyone ?
More about : ati radeon 4870x2 gpu problem
a c 198 U Graphics card
August 29, 2012 4:14:49 PM
What power supply are you running? Download GPU-Z from techpowerup and it will tell you more detailed information.
August 30, 2012 8:56:13 AM
my power supply is thermaltake tr2-500 watt (i think problem is not psu.) it was working with this psu.
August 30, 2012 6:02:09 PM
Well it does show the 4870X2, so in theory it should be working. The TR2 in my opinion is definitely not enough to power that card. I would change it.
But your GPU seems to be fine.
August 30, 2012 9:25:33 PM
it shows 1 gpu, it needs to be 2 gpu ???
August 30, 2012 10:12:32 PM
I don't think so.
September 3, 2012 9:51:21 PM
i solved it !!! the problem was mobo i changed it and boom it works like magic
