As I re-read my previous question I realized I did not state my problem correctl
  • Laptops
  • Connection
  • Components
Last response: in Components
March 8, 2013 7:13:13 PM
As I re-read my previous question I realized I did not state my problem correctly. The key board is in my Toshiba laptop. To remove the key board from the laptop’s base it is necessary to disconnect a series of wires which are plugged into the base of the laptop. The wires connected the keyboard have a male plug on the end which connects to a female socket on the laptop base. To remove or install the wires you first have to remove a small plastic clip that secures this connection so that it does not unplug/ disconnect accidently.
More about : read previous question realized state problem correctl
a b D Laptop
March 8, 2013 7:45:04 PM
You may have to re-state the problem, and the question.
m
l
