Solved
NEW Build HELP
Approximate Purchase Date: Today, Tomorrow
Budget Range: $1250
System Usage from Most to Least Important: Gaming, Animation
Are you buying a monitor: No
Do you need to buy OS: Yes (Windows 7)
Preferred Website(s) for Parts: Any
Parts Preferences: Intel I5/I7, At least a GTX 660Ti
Overclocking: Maybe
SLI or Crossfire: No
Parts so far: Asus DVD Drive: $20
Seagate Barracuda HDD: $90
Asus GTX 660Ti 2GB: $330
Cooler Master Silent Pro 850W: $140
CORSAIR Vengeance 8GB: $38
GIGABYTE GA-Z68X-UD3H-B3: $150
Intel Core i5-3570K: $230
COOLER MASTER Hyper 212 $30
Windows 7: $100
Good so far?
25 answers Last reply Best Answer
More about build help
  1. Best answer
  2. Heh, I came up with a very similar build to TheBigtroll. Have a look:
    CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($319.99 @ Amazon)
    CPU Cooler: Xigmatek GAIA SD1283 56.3 CFM CPU Cooler ($19.99 @ Newegg)
    Motherboard: Gigabyte G1.Sniper M3 Micro ATX LGA1155 Motherboard ($149.99 @ Newegg)
    Storage: Crucial M4 128GB 2.5" Solid State Disk ($89.99 @ Amazon)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
    Video Card: Gigabyte GeForce GTX 670 2GB Video Card ($359.99 @ Amazon)
    Case: Zalman Z11 Plus HF1 ATX Mid Tower Case ($71.34 @ NCIX US)
    Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($59.99 @ NCIX US)
    Optical Drive: LG GH24NS90 DVD/CD Writer ($15.99 @ Newegg)
    Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($91.99 @ Amazon)
    Total: $1249.25
    Note that you get 8GB of RAM for free with the motherboard thanks to a promo Newegg is running. I believe today is also the last day to get Win7 from them for $80 using promo code EMCJNHG253.
    Now, there are some options / choices you can make here. If you're not really serious about the animation, I'd go with the i5 instead of the i7 and put that $100 towards a bigger SSD, or back in your pocket.
    You could also get a less expensive Gigabyte motherboard with the same relevant features that is also eligible for the free RAM promo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128542
    Obviously you can ratchet your SSD/HDD capacity up or down to save money or to spend it if you save elsewhere.
    If you aren't partial to nvidia GPUs (as I am), the 7970 with recent drivers would be a minor upgrade for $20 more: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150596&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
    Either card will give you all the muscle you can handle for single monitor gaming and then some. If you're on a single display, it's pretty unlikely you'd ever notice a difference between the two.
    There are about a million options for cases, and you could spend more, or even save some money here and still be fine. Find one with an aesthetic you like and go from there.
  3. Thanks for the fast replies. I honestly thought 750w was standard. Thanks for letting me know. Also I have a question. We might be adding this to the PC later on http://www.amazon.com/Blackmagic-Design-Intensity-Pro-Editing/dp/B001CN9GEA would we need to upgrade the PSU if we do?
  4. Here's a build for gaming + multi-threaded programs.
    EDIT: It's an AMD build though, I just noticed you preferred Intel, sorry. Just treat this as an alternative then. :)
    CPU: AMD FX-8320 3.5GHz 8-Core Processor ($179.99 @ Newegg)
    Motherboard: ASRock 990FX Extreme3 ATX AM3+/AM3 Motherboard ($119.99 @ Amazon)
    Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory ($81.99 @ Newegg)
    Storage: OCZ Vertex 4 128GB 2.5" Solid State Disk ($99.99 @ Newegg)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
    Case: Rosewill BlackHawk ATX Mid Tower Case ($89.99 @ Amazon)
    Power Supply: OCZ ZT 750W 80 PLUS Bronze Certified ATX12V Power Supply ($79.98 @ NCIX US)
    Total: $1189.89
  5. Excella recommending an OCZ power supply?! /scandalized
    Also, I was reminded recently that I think you need Pro or higher to use more than 8GB of RAM.
    Otherwise looks good, as usual ;)
  6. You don't need Pro to use more than 8GB... you need pro to use more than 16GB
    LOL. These recent ones are of good quality and efficiency. :)
    The ModXStream and EliteXStream is still pretty horrible though.
    Also, I feel like I'm missing out on something - what do you guys mean on "pro"?
  8. I changed some things on TheBigTroll link. Here it is http://pcpartpicker.com/p/lnCw is it good? Anything I degrade to add?
    I assumed he meant windows and confused himself as to what can address what.
    StealthXstream (first version not stealthxstream2) had some question marks as well and personally I am not sure on CoreXstream as there are no proper reviews on it and it's cheap as hell these are all old models though. Agree with the rest I actually like OCZ for PSU's the ZS series is very good at a pricepoint often cheaper than other stuff that is its equal. ZT is less great but price makes up for that. Fatal1ty are a rip off (pricingwise not quality).
    Buy a 670 its 25% cheaper than a 680 but under 10% less performance (and a decent one can be clocked to 680 levels).
    Dunno about your PSU we dont have Rosewill here in the UK so it's not something I can comment on.
    I would buy a board made by ASUS or Gbyte that extreme 4 uses cheap mofsets and is even smaller than ATX should be (and thinner) all in all its giving features over quality, depends which you prefer though.
    I will be buying the GTX 670. (2gb or 4gb?)
    I switched out the Mobo for http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
  12. 2GB version will be fine unless you plan on multiple monitors at massive resolutions
    I won't be. Thanks for answering my question. Everything is compatible correct? I just wanted to make sure that a 550w supply was good enough for the current set up and for future ones. (Will be adding http://www.amazon.com/Blackmagic-Design-Intensity-Pro-Editing/dp/B001CN9GEA?tag=vglnk-c1001-20 or something similar in the future)
  14. I dont know that PSU so wouldn't approve it myself I'd get something like this http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 after the mail in rebate thats a really good price. Like I said though a US member can likely comment better on the Rosewill unit.
    Derp. Yeah, sorry. Sleep deprivation posting fail. >.<
    You didn't miss anything, I'm just retarded. I knew something seemed off when I was posting that, I should have just taken the 30 seconds to double check. :sweat:
  17. the zt series are rather mediocre. ever heard of the jet engine fan noise problem?
    and what ever you changed is a bad choice.
    680s are rip offs
    asus video cards are no better
    a 550w capstone makes no sense. id just get a xfx 550w for 59.99 and call it a day. 8-+ gold is not worth the cash at this low level of wattage
    get a newer case like the arc midi from fractal. or get the haf xm. older cases lack new features
  18. ^did a few research, and it seems not all units were subject to the fan noise, and the recent releases don't have it anymore. The people who sent theirs for replacement lost the issue.
  19. still. stick with seasonic or superflower
  20. Thanks for all the feedback.
    If I purchase the 650/550w PSU I still have $100 or so dollars to spare. Should I upgrade to i7 2600k or stick with the i5 3570k I have in the cart? Thinking of spending a bit more to also add a SSD. So far I have purchased the Disc drive, Motherboard, Hard Drive, CPU Cooler, 8GB RAM, and Windows 7. I should be receiving the items in a couple of hours. I just need the PSU, CPU, Video Card, and Case now.
  22. stick with the i5. i7s have no performance increase
    Will do. Thanks. I was just making sure since I start animation soon.
  24. I would definitely spend the extra $100 on an SSD.
  25. Best answer selected by uploadcomplete.
New Build Systems Product
