Archived from groups: alt.cellular.nokia,uk.telecom.mobile (More info?)
Hi.
I'm just thinking about whether or not to invest in a USB dongle/adapter for
use with my Nokia 7610 and Nokia PC Suite.
I currently use the USB cable that was supplied with the phone, however the
convenience of the bluetooth sounds good, so you don't have to keep
plugging/unplugging the phone (lazy I know!).
Can anyone give me some sort of idea of a speed comparison for transferring
files, as a friend of mine seems to think that the bluetooth is slower.
Also, has anyone had any problems/compatabiity issues with bluetooth that I
should avoid, and can anyone reccommend a good adapter to me? Does the
coverage range vary between adapters? Most I have seen quote 10 metres,
although I have seen one quote a figure of 25 metres.
Bluetooth is slower. Your friend is correct. Sorry I don't have exact
numbers but I can tell you it's not by much. If you are interested I am
certain that a search in Google.com will yield an answer.
Belkin seems to be a good reliable brand. As long as you get a recent model
Bluetooth dongle from a reputable manufacturer you should be fine.
You will find some great deals on eBay. I would recommend getting a
second-hand one from eBay because the new ones that sell for low prices are
either some off-brand type or old discontinued ones that happen to be in
their original shrink-wrapped box.
"James Lawrence" <no@mail.please> wrote in message
news:4192bc16$0$10378$cc9e4d1f@news-text.dial.pipex.com...
> Hi.
> for use with my Nokia 7610 and Nokia PC Suite.
> the convenience of the bluetooth sounds good, so you don't have to keep
> transferring files, as a friend of mine seems to think that the bluetooth
> is slower.
> I should avoid, and can anyone reccommend a good adapter to me? Does the
> Thanks very much,
> James.
I have a 7610, and use Bluetooth at work, and the cable at home. The cable
is much more convenient, particularly as there is a problem with PC-Suite
and Bluetooth on the 7610, which means you have to pair the devices every
time you reboot your PC. That takes much longer than plugging the cable in.
I am thinking of buying anther cable and forgetting the Bluetooth.
> Hi.
for
the
transferring
I
> Thanks very much,
> James.
On Wed, 10 Nov 2004 20:28:03 -0800, "Julie Ruin"
Interesting ..... so presumably this would apply to handheld PC's as
well (Palm) ?
> Hi.
> Thanks very much,
> James.
Apparently, the phone is only capable of 10 metres, so it won't matter how
far the dongle will transmit.
Thanks for all the replies.
Interesting to find out the phone only has a range of 10 metres irrespective
of the type of dongle, and most of all the fact that I'd have to pair the
phone up after every reboot. That certainly outweighs the advantages of
using the Bluetooth connection for me, combined with the fact that it's
slightly slower anyway.
Think I'll stick to the USB connection for now (or at least until they fix
the pair after every reboot problem, if they ever manage to).
