G
Guest
Guest
I’ve set up four Baracuda IV 20GB Drives on a Promise Fastrack 100 TX4 controller. The controller has four channels and I’ve set each drive as master. I set the controller mode for stripe, and the stripe size at 64KB. I went into WinME, installed the drivers and used the Computer Management tool to format the RAID drive as single 80GB NTFS partition. I ran the SiSoft Sandra Drives Benchmark and was surprised to see my raid drive operating at the same speed as my primary IDE Drive about 20 MBS.My performance is much less than expected. I get only 20000 !!! in Sisoft drive benchmark (I got around 25000 or so with a single Baracuda IV 20 GB drive!). I also only get 5500 score in Winbench 99 Business disk test, and only 15000 in the high-end disk test.
Now what could be the problem? Did I set up my RAID wrong? Is my controller card the problem? Any suggestions would be greatly appreciated! Thank you!
Mark
Mark
